Date/Time: Fri, 29 Mar 2024 14:25:55 +0000
Copy chart drawings between chartbooks
View Count: 1573
[2019-08-20 12:21:04] |
User33743 - Posts: 83 |
Hello, Is this possible to automatically copying chart drawing between charts of different chartbooks? Could you help me with this? Best Regards |
[2019-08-20 20:30:09] |
Refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Specifically the 4th paragraph in that section that starts with Copying Chart Drawings from Other Chartbooks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
