Date/Time: Fri, 26 Apr 2024 23:54:25 +0000
Tool Value Window disappear
View Count: 506
[2019-08-20 04:39:57] |
nicktrader - Posts: 665 |
I used SC with a higher resolution monitor (4K). Now I am still using a FHD Monitor. Since than the Tool Value Window do not appear. All other windows like "Current Quote Window" or "Chart Value Window" are visible.
[2019-08-20 08:21:16] |
Do you not know how to perform a reset of windows? Refer to: Window and CW Menus: Reset Windows (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
