Date/Time: Sat, 20 Apr 2024 07:54:23 +0000
questions
View Count: 566
[2019-08-19 20:50:30] |
User262199 - Posts: 2 |
I have a question, I noticed that my sierra charts show different opens when I scroll is that normal? Is there a way to see previous daily opens, highs, and lows, as well as closes like a table or something in studies? |
[2019-08-20 03:12:44] |
We do not understand the first question. For a table view of the data in a chart, use the Spreadsheet study: Overview of Spreadsheet Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-20 12:30:54] |
Reference I noticed that my sierra charts show different opens when I scroll is that normal? The different opens you know where it it says Open High Low Close the numbers are different when I scroll |
[2019-08-20 20:37:40] |
We assume that you are referring to the information in the Chart Values Window. The information in that window changes to display the information for the right-most bar that is displayed in the chart. So as you scroll, that bar is changing and the numbers change with it. Refer to the following for more information on this window: Window and CW Menus: Chart Values Window (Window) Note that the Tool Values Window and the Compact Tool Values Window show you the information for the bar where the cursor is located. You will find the information on those windows just below the section linked above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
