Date/Time: Fri, 29 Mar 2024 08:52:04 +0000
unknown Alert Source
View Count: 953
[2013-12-08 16:23:39] |
User39772 - Posts: 311 |
While SC app is open I get Sound Alerts every know and then even if the market is closed (i.e. on weekends). Message Log and Alert Manager is empty while this happens. Any idea how I can find out where the alert comes from ? |
[2013-12-08 19:30:50] |
Almost certainly therefore it is not coming from Sierra Chart. Do you still hear it if you exit from Sierra Chart?
