Date/Time: Fri, 19 Apr 2024 09:07:33 +0000
Is there way to duplicate trades?
View Count: 570
[2019-08-19 08:30:46] |
Vasyl Boshkov - Posts: 10 |
Hi! Is there way to duplicate trades on 2-3 of my different accounts of Sierra chart? Thanks in advance. |
[2019-08-21 17:55:35] |
Hi, Can you please answer my question?
[2019-08-21 18:23:53] |
Yes. This is explained here: Order Allocation to Trade Accounts This is only supported within a single instance of Sierra Chart. And the trading service Sierra Chart is connected to needs to have multiple trading accounts assigned to the username used to log into that service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-23 12:48:08] |
Thank you for your answer, but i was mean 2 accounts from 2 different brokers. Thank you again |
