Date/Time: Fri, 19 Apr 2024 09:29:46 +0000
Bigger Overlay For Displayed Period?
View Count: 555
[2019-08-19 02:11:25] |
User218474 - Posts: 8 |
I'm running several displays simultaneously with different time frames. Is there any way to display the current period for each respective chart in a larger font similar to how time is displayed? The current positioning is very tiny and takes extra mental resources to find. |
[2019-08-19 06:07:24] |
If you want to make the fonts/text larger. Refer to: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-19 20:27:09] |
Yep, I saw those options, but I meant just for changing the period font. The other information is superfluous for my view and I'd like to keep all the other fonts the same size.
