Date/Time: Thu, 28 Mar 2024 10:08:48 +0000
Custom Calculated Symbols
View Count: 688
[2019-08-18 22:47:44] |
cmb999 - Posts: 211 |
hi, having some trouble with this feature. there are many settings for a symbol, trying to create {ES?##}*{ENQ?##} i attached screenshot. is there setting missing ? |
custom_symbol_1.png / V - Attached On 2019-08-18 22:45:45 UTC - Size: 151.79 KB - 229 views Attachment Deleted. |
[2019-08-18 23:10:48] |
That is not correct. You do not set the Underlying Symbol. The New symbol added needs to be a very specific formula with specific symbols: Custom Calculated Symbols: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
