Date/Time: Sat, 20 Apr 2024 10:11:08 +0000
Highlight Non Zero Bid&Ask Pullback Column
View Count: 829
[2019-08-17 15:06:29] |
Chris_uk - Posts: 89 |
Hello, When using the Numbers Bars study, Is it possible to please have an option to stop the 'Highlight Non Zero Bid&Ask Volume at High/Low' from highlighting the Pullback Column, It can be a little distracting. Screenshot http://www.sierrachart.com/image.php?Image=156605389310.png Many Thanks! Date Time Of Last Edit: 2019-08-17 15:07:14
[2019-08-19 19:09:59] |
John - SC Support - Posts: 30976 |
We have added an Input to the Numbers Bars entitled Highlight Bid&Ask at High/Low in Pullback Columns that will allow you to turn off this specific highlighting in the pullback columns. This will be in the next pre-release - v1977. When available, you can update using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-19 20:01:47] |
Many Thanks!
