Date/Time: Fri, 29 Mar 2024 07:09:05 +0000
Never Ending Repeat of Connect/Disconnect Messages in Message Log after Installing 1061
View Count: 1122
[2013-12-08 15:16:52] |
graggy - Posts: 15 |
I alternatively use both OEC and TT FIX data sources from the same instantiation of Sierra Chart. I also subscribe to the SC "Real-Time CME Data Feed (CME,CBOT,NYMEX,COMEX data)". I have the "Allow Support for Sierra Chart Data Feeds" box checked for both services. On the TT FIX "Service Settings" page I have the "Use CME Gateway for CBOT Symbols" box checked. After reading the 1061 version notes and installing 1061 via the Help Menu I did the following steps (as an aside, the 1061 "Release Date" in the blue highlighted line is wrong on the version notes page): 1. Made TT FIX the active service by selecting "File ---> Data/Trade Service Settings ---> TT FIX". 2. Pressed "Full Reset" on the "Global Symbol Settings" page for TT FIX. 3. Made OEC the active service by selecting "File ---> Data/Trade Service Settings ---> Open E Cry". Now whenever OEC is the active service, and is connected, I get a never-ending repeating stream of the following in the Message Log: (NOTE: Please be assured that I have tried many obvious tactics to avoid this problem (for example: connecting/disconnecting; restarting SC; pressing Full Reset again for both Services; etc..... Apparently some TT FIX eurex setting is being improperly applied to combo "OEC/SC Realtime" connections). Software version: 1061 | 2013-12-08 10:11:52 Usage end date: 2014-03-04 | 2013-12-08 10:11:52 Enabled for: Sierra Chart Historical Data Service. | 2013-12-08 10:11:52 Enabled for: Sierra Chart Real-Time Futures Data Service for Trading Services. | 2013-12-08 10:11:52 Received 1 data feed usernames. | 2013-12-08 10:11:52 Allow Support for Sierra Chart Data Feeds is enabled. | 2013-12-08 10:11:52 Active service: Open E Cry | 2013-12-08 10:11:52 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-08 10:11:52 2013-12-08 10:11:52 Local computer clock time | 2013-12-08 10:11:52 2013-12-08 15:11:52 GMT time | 2013-12-08 10:11:52 2013-12-08 10:11:52 Time zone adjusted time | 2013-12-08 10:11:52 Time difference to server time: 0 seconds. | 2013-12-08 10:11:52 Program path: C:\SC-scFeed\1\ | 2013-12-08 10:11:52 Data Files path: C:\SC-scFeed\1\Data\ | 2013-12-08 10:11:52 OS Version Number: 6.1 | 2013-12-08 10:11:52 Checking for new symbol settings for oec | 2013-12-08 10:11:52 Mapping GCLF4 to CLF4. Service code: nymex | 2013-12-08 10:11:56 Mapping GCLG4 to CLG4. Service code: nymex | 2013-12-08 10:11:56 HD Request # 2 - Downloading Intraday chart data for GCLF4 to the file GCLF4.scid. Service: nymex | 2013-12-08 10:11:56 HD Request # 2 - Last Date-Time in file: 2013-12-06 17:14:58.0 | 2013-12-08 10:11:56 HD Request # 2 - Using server: scdf1.sierracharts.com port 10149 | 2013-12-08 10:11:56 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:11:56 Mapping GRBF4 to RBF4. Service code: nymex | 2013-12-08 10:11:56 Mapping GHOF4 to HOF4. Service code: nymex | 2013-12-08 10:11:56 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:56 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:56 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:56 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:56 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:56 The network socket is connected. | 2013-12-08 10:11:56 HD Request # 2 - Sending historical data logon request message. | 2013-12-08 10:11:56 HD Request # 2 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:11:56 HD Request # 2 - Decompressing data. | 2013-12-08 10:11:57 HD Request # 2 - Receiving Intraday data for GCLF4 starting at 2013-12-06 17:14:58 | 2013-12-08 10:11:57 HD Request # 2 - Historical data for GCLF4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 10:11:57 The network socket for historical data has been closed. | 2013-12-08 10:11:57 HD Request # 2 - Received 2 records from 2013-12-06 17:14:58 to 2013-12-06 17:14:58 (0.0 seconds) and wrote 0 records for GCLF4 | 2013-12-08 10:11:57 HD Request # 2 - Intraday download COMPLETE for GCLF4 | 2013-12-08 10:11:57 HD Request # 3 - Downloading Intraday chart data for GCLG4 to the file GCLG4.scid. Service: nymex | 2013-12-08 10:11:57 HD Request # 3 - Last Date-Time in file: 2013-12-06 17:14:35.0 | 2013-12-08 10:11:57 HD Request # 3 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 10:11:57 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:11:57 The network socket is connected. | 2013-12-08 10:11:57 HD Request # 3 - Sending historical data logon request message. | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: RLM-MZ3 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: RLM-MZ3 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: RLM-MZ3 | 2013-12-08 10:11:57 Mapping NQZ3 to NQZ3. Service code: cme | 2013-12-08 10:11:57 HD Request # 3 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 HD Request # 3 - Decompressing data. | 2013-12-08 10:11:57 HD Request # 3 - Receiving Intraday data for GCLG4 starting at 2013-12-06 17:14:35 | 2013-12-08 10:11:57 HD Request # 3 - Historical data for GCLG4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 10:11:57 The network socket for historical data has been closed. | 2013-12-08 10:11:57 HD Request # 3 - Received 1 record from 2013-12-06 17:14:35 to 2013-12-06 17:14:35 (0.0 seconds) and wrote 0 records for GCLG4 | 2013-12-08 10:11:57 HD Request # 3 - Intraday download COMPLETE for GCLG4 | 2013-12-08 10:11:57 HD Request # 4 - Downloading Intraday chart data for GRBF4 to the file GRBF4.scid. Service: nymex | 2013-12-08 10:11:57 HD Request # 4 - Last Date-Time in file: 2013-12-06 17:14:58.0 | 2013-12-08 10:11:57 HD Request # 4 - Using server: scdf1.sierracharts.com port 10149 | 2013-12-08 10:11:57 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:11:57 The network socket is connected. | 2013-12-08 10:11:57 HD Request # 4 - Sending historical data logon request message. | 2013-12-08 10:11:57 HD Request # 4 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:11:57 HD Request # 4 - Decompressing data. | 2013-12-08 10:11:57 HD Request # 4 - Receiving Intraday data for GRBF4 starting at 2013-12-06 17:14:58 | 2013-12-08 10:11:57 HD Request # 4 - Historical data for GRBF4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 10:11:57 The network socket for historical data has been closed. | 2013-12-08 10:11:57 HD Request # 4 - Received 2 records from 2013-12-06 17:14:58 to 2013-12-06 17:14:58 (0.0 seconds) and wrote 0 records for GRBF4 | 2013-12-08 10:11:57 HD Request # 4 - Intraday download COMPLETE for GRBF4 | 2013-12-08 10:11:57 HD Request # 5 - Downloading Intraday chart data for GHOF4 to the file GHOF4.scid. Service: nymex | 2013-12-08 10:11:57 HD Request # 5 - Last Date-Time in file: 2013-12-06 17:12:37.0 | 2013-12-08 10:11:57 HD Request # 5 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 10:11:57 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 The network socket is connected. | 2013-12-08 10:11:57 HD Request # 5 - Sending historical data logon request message. | 2013-12-08 10:11:57 HD Request # 5 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:11:57 HD Request # 5 - Decompressing data. | 2013-12-08 10:11:57 HD Request # 5 - Receiving Intraday data for GHOF4 starting at 2013-12-06 17:12:37 | 2013-12-08 10:11:57 HD Request # 5 - Historical data for GHOF4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 10:11:57 The network socket for historical data has been closed. | 2013-12-08 10:11:57 HD Request # 5 - Received 13 records from 2013-12-06 17:12:37 to 2013-12-06 17:12:37 (0.0 seconds) and wrote 0 records for GHOF4 | 2013-12-08 10:11:57 HD Request # 5 - Intraday download COMPLETE for GHOF4 | 2013-12-08 10:11:57 HD Request # 6 - Downloading Intraday chart data for RLM-MZ3 to the file RLM-MZ3.scid. Service: oec | 2013-12-08 10:11:57 HD Request # 6 - Last Date-Time in file: 2013-12-06 17:59:59.0 | 2013-12-08 10:11:57 HD Request # 6 - Using server: ds5.sierracharts.com port 10149 | 2013-12-08 10:11:57 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-08 10:11:57 The network socket is connected. | 2013-12-08 10:11:57 HD Request # 6 - Sending historical data logon request message. | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:57 HD Request # 6 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:11:57 HD Request # 6 - Historical data for RLM-MZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 10:11:57 The network socket for historical data has been closed. | 2013-12-08 10:11:57 HD Request # 6 - Received 0 records and wrote 0 records for RLM-MZ3 | 2013-12-08 10:11:57 HD Request # 6 - Intraday download COMPLETE for RLM-MZ3 | 2013-12-08 10:11:57 HD Request # 7 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: cme | 2013-12-08 10:11:57 HD Request # 7 - Last Date-Time in file: 2013-12-06 17:14:59.0 | 2013-12-08 10:11:57 HD Request # 7 - Using server: scdf1.sierracharts.com port 10149 | 2013-12-08 10:11:58 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:11:58 The network socket is connected. | 2013-12-08 10:11:58 HD Request # 7 - Sending historical data logon request message. | 2013-12-08 10:11:58 HD Request # 7 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 HD Request # 7 - Decompressing data. | 2013-12-08 10:11:58 HD Request # 7 - Receiving Intraday data for NQZ3 starting at 2013-12-06 17:14:59 | 2013-12-08 10:11:58 HD Request # 7 - Historical data for NQZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-08 10:11:58 The network socket for historical data has been closed. | 2013-12-08 10:11:58 HD Request # 7 - Received 1 record from 2013-12-06 17:14:59 to 2013-12-06 17:14:59 (0.0 seconds) and wrote 0 records for NQZ3 | 2013-12-08 10:11:58 HD Request # 7 - Intraday download COMPLETE for NQZ3 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:58 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:11:59 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:00 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:01 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:02 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:03 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:03 Connecting to Open E Cry server: prod.openecry.com:9200... | 2013-12-08 10:12:03 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:07 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:07 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:07 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:07 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 Open E Cry: Connected. | 2013-12-08 10:12:08 Mapping GCLF4 to CLF4. Service code: nymex | 2013-12-08 10:12:08 SC Data Service - Starting real-time market data updates for: CLF4 | 2013-12-08 10:12:08 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:08 Mapping GRBF4 to RBF4. Service code: nymex | 2013-12-08 10:12:08 SC Data Service - Starting real-time market data updates for: RBF4 | 2013-12-08 10:12:08 Mapping GHOF4 to HOF4. Service code: nymex | 2013-12-08 10:12:08 SC Data Service - Starting real-time market data updates for: HOF4 | 2013-12-08 10:12:08 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:08 HD Request # 8 - Downloading Intraday chart data for GCLF4 to the file GCLF4.scid. Service: nymex | 2013-12-08 10:12:08 HD Request # 8 - Last Date-Time in file: 2013-12-06 17:14:58.0 | 2013-12-08 10:12:08 HD Request # 8 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 10:12:08 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 Open E Cry - Starting real-time market data updates for: NSEA-MF4 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: NSEA-MF4 | 2013-12-08 10:12:08 HD Request # 9 - Downloading Intraday chart data for NSEA-MF4 to the file NSEA-MF4.scid. Service: oec | 2013-12-08 10:12:08 HD Request # 9 - Last Date-Time in file: 2013-12-06 17:56:35.0 | 2013-12-08 10:12:08 The network socket is connected. | 2013-12-08 10:12:08 SC Data Service: Connected to server. | 2013-12-08 10:12:08 SC Data Service: Sending logon request message. | 2013-12-08 10:12:08 The network socket is connected. | 2013-12-08 10:12:08 HD Request # 8 - Sending historical data logon request message. | 2013-12-08 10:12:08 HD Request # 8 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:12:08 Open E Cry tick subscription ID: 2 | 2013-12-08 10:12:08 HD Request # 9 - Requesting Historical Tick data from 2013-12-06 22:56:35 (UTC) to 2013-12-08 15:12:08 (UTC). | 2013-12-08 10:12:08 HD Request # 9 - Open E Cry history request subscription ID: 3 | 2013-12-08 10:12:08 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:08 Socket closed. No error. | 2013-12-08 10:12:08 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:08 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:08 Mapping GCLG4 to CLG4. Service code: nymex | 2013-12-08 10:12:08 SC Data Service - Starting real-time market data updates for: CLG4 | 2013-12-08 10:12:08 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:08 HD Request # 8 - Decompressing data. | 2013-12-08 10:12:08 HD Request # 8 - Receiving Intraday data for GCLF4 starting at 2013-12-06 17:14:58 | 2013-12-08 10:12:08 The network socket for historical data has been closed. | 2013-12-08 10:12:08 HD Request # 8 - Received 2 records from 2013-12-06 17:14:58 to 2013-12-06 17:14:58 (0.0 seconds) and wrote 0 records for GCLF4 | 2013-12-08 10:12:08 HD Request # 8 - Intraday download COMPLETE for GCLF4 | 2013-12-08 10:12:08 Real-time Intraday chart data file updates started for GCLF4 | 2013-12-08 10:12:08 HD Request # 10 - Downloading Intraday chart data for GRBF4 to the file GRBF4.scid. Service: nymex | 2013-12-08 10:12:08 HD Request # 10 - Last Date-Time in file: 2013-12-06 17:14:58.0 | 2013-12-08 10:12:08 HD Request # 10 - Using server: scdf1.sierracharts.com port 10149 | 2013-12-08 10:12:08 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:08 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:08 HD Request # 9 - OEC Trading service: Receiving intraday tick data for NSEA-MF4. (Subscription ID: 3) | 2013-12-08 10:12:08 HD Request # 9 - OEC Trading service: Request 1 for NSEA-MF4: Received 1 records from 12/6/2013 5:56:35 PM to 12/6/2013 5:56:35 PM. | 2013-12-08 10:12:08 HD Request # 9 - Requesting Historical Tick data from 2013-12-06 22:56:35 (UTC) to 2013-12-06 22:56:35 (UTC). | 2013-12-08 10:12:08 HD Request # 9 - Open E Cry history request subscription ID: 4 | 2013-12-08 10:12:08 The network socket is connected. | 2013-12-08 10:12:08 HD Request # 10 - Sending historical data logon request message. | 2013-12-08 10:12:08 The network socket is connected. | 2013-12-08 10:12:08 SC Data Service: Connected to server. | 2013-12-08 10:12:08 SC Data Service: Sending logon request message. | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: RLM-MZ3 | 2013-12-08 10:12:08 Open E Cry - Starting real-time market data updates for: RLM-MZ3 | 2013-12-08 10:12:08 No SC real-time data feed mapping found for symbol: RLM-MZ3 | 2013-12-08 10:12:08 Mapping NQZ3 to NQZ3. Service code: cme | 2013-12-08 10:12:08 SC Data Service - Starting real-time market data updates for: NQZ3 | 2013-12-08 10:12:08 HD Request # 10 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:12:08 HD Request # 9 - OEC Trading service: Request 2 for NSEA-MF4: Received 0 records. | 2013-12-08 10:12:08 HD Request # 9 - Receiving Intraday data for NSEA-MF4 starting at 2013-12-06 17:56:35 | 2013-12-08 10:12:08 HD Request # 9 - Received 1 record from 2013-12-06 17:56:35 to 2013-12-06 17:56:35 (0.0 seconds) and wrote 0 records for NSEA-MF4 | 2013-12-08 10:12:08 HD Request # 9 - Intraday download COMPLETE for NSEA-MF4 | 2013-12-08 10:12:08 HD Request # 10 - Decompressing data. | 2013-12-08 10:12:08 HD Request # 10 - Receiving Intraday data for GRBF4 starting at 2013-12-06 17:14:58 | 2013-12-08 10:12:08 The network socket for historical data has been closed. | 2013-12-08 10:12:08 Real-time Intraday chart data file updates started for NSEA-MF4 | 2013-12-08 10:12:08 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:08 Socket closed. No error. | 2013-12-08 10:12:08 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:08 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:08 HD Request # 10 - Received 2 records from 2013-12-06 17:14:58 to 2013-12-06 17:14:58 (0.0 seconds) and wrote 0 records for GRBF4 | 2013-12-08 10:12:08 HD Request # 10 - Intraday download COMPLETE for GRBF4 | 2013-12-08 10:12:08 Real-time Intraday chart data file updates started for GRBF4 | 2013-12-08 10:12:08 Open E Cry tick subscription ID: 6 | 2013-12-08 10:12:08 HD Request # 11 - Downloading Intraday chart data for GHOF4 to the file GHOF4.scid. Service: nymex | 2013-12-08 10:12:08 HD Request # 11 - Last Date-Time in file: 2013-12-06 17:12:37.0 | 2013-12-08 10:12:08 HD Request # 11 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 10:12:08 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:08 The network socket is connected. | 2013-12-08 10:12:08 HD Request # 11 - Sending historical data logon request message. | 2013-12-08 10:12:08 HD Request # 11 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:12:08 HD Request # 11 - Decompressing data. | 2013-12-08 10:12:09 HD Request # 11 - Receiving Intraday data for GHOF4 starting at 2013-12-06 17:12:37 | 2013-12-08 10:12:09 The network socket for historical data has been closed. | 2013-12-08 10:12:09 HD Request # 11 - Received 13 records from 2013-12-06 17:12:37 to 2013-12-06 17:12:37 (0.0 seconds) and wrote 0 records for GHOF4 | 2013-12-08 10:12:09 HD Request # 11 - Intraday download COMPLETE for GHOF4 | 2013-12-08 10:12:09 Real-time Intraday chart data file updates started for GHOF4 | 2013-12-08 10:12:09 HD Request # 12 - Downloading Intraday chart data for GCLG4 to the file GCLG4.scid. Service: nymex | 2013-12-08 10:12:09 HD Request # 12 - Last Date-Time in file: 2013-12-06 17:14:35.0 | 2013-12-08 10:12:09 HD Request # 12 - Using server: scdf1.sierracharts.com port 10149 | 2013-12-08 10:12:09 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:09 The network socket is connected. | 2013-12-08 10:12:09 HD Request # 12 - Sending historical data logon request message. | 2013-12-08 10:12:09 HD Request # 12 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:12:09 HD Request # 12 - Decompressing data. | 2013-12-08 10:12:09 HD Request # 12 - Receiving Intraday data for GCLG4 starting at 2013-12-06 17:14:35 | 2013-12-08 10:12:09 The network socket for historical data has been closed. | 2013-12-08 10:12:09 HD Request # 12 - Received 1 record from 2013-12-06 17:14:35 to 2013-12-06 17:14:35 (0.0 seconds) and wrote 0 records for GCLG4 | 2013-12-08 10:12:09 HD Request # 12 - Intraday download COMPLETE for GCLG4 | 2013-12-08 10:12:09 Real-time Intraday chart data file updates started for GCLG4 | 2013-12-08 10:12:09 HD Request # 13 - Downloading Intraday chart data for RLM-MZ3 to the file RLM-MZ3.scid. Service: oec | 2013-12-08 10:12:09 HD Request # 13 - Last Date-Time in file: 2013-12-06 17:59:59.0 | 2013-12-08 10:12:09 HD Request # 13 - Using server: ds4.sierracharts.com port 10149 | 2013-12-08 10:12:09 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-08 10:12:09 The network socket is connected. | 2013-12-08 10:12:09 HD Request # 13 - Sending historical data logon request message. | 2013-12-08 10:12:09 HD Request # 13 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:12:09 The network socket for historical data has been closed. | 2013-12-08 10:12:09 HD Request # 13 - Received 0 records and wrote 0 records for RLM-MZ3 | 2013-12-08 10:12:09 HD Request # 13 - Intraday download COMPLETE for RLM-MZ3 | 2013-12-08 10:12:09 Real-time Intraday chart data file updates started for RLM-MZ3 | 2013-12-08 10:12:09 HD Request # 14 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: cme | 2013-12-08 10:12:09 HD Request # 14 - Last Date-Time in file: 2013-12-06 17:14:59.0 | 2013-12-08 10:12:09 HD Request # 14 - Using server: scdf2.sierracharts.com port 10149 | 2013-12-08 10:12:09 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:09 The network socket is connected. | 2013-12-08 10:12:09 HD Request # 14 - Sending historical data logon request message. | 2013-12-08 10:12:09 HD Request # 14 - Requesting up to 100 days of Intraday data. Record interval: 0 | 2013-12-08 10:12:09 HD Request # 14 - Decompressing data. | 2013-12-08 10:12:09 HD Request # 14 - Receiving Intraday data for NQZ3 starting at 2013-12-06 17:14:59 | 2013-12-08 10:12:09 The network socket for historical data has been closed. | 2013-12-08 10:12:09 HD Request # 14 - Received 1 record from 2013-12-06 17:14:59 to 2013-12-06 17:14:59 (0.0 seconds) and wrote 0 records for NQZ3 | 2013-12-08 10:12:09 HD Request # 14 - Intraday download COMPLETE for NQZ3 | 2013-12-08 10:12:09 Real-time Intraday chart data file updates started for NQZ3 | 2013-12-08 10:12:09 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:10 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:10 The network socket is connected. | 2013-12-08 10:12:10 SC Data Service: Connected to server. | 2013-12-08 10:12:10 SC Data Service: Sending logon request message. | 2013-12-08 10:12:10 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:10 Socket closed. No error. | 2013-12-08 10:12:10 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:10 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:10 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:12 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:12 The network socket is connected. | 2013-12-08 10:12:13 SC Data Service: Connected to server. | 2013-12-08 10:12:13 SC Data Service: Sending logon request message. | 2013-12-08 10:12:13 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:13 Socket closed. No error. | 2013-12-08 10:12:13 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:13 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:13 Requesting market depth updates for: GCLF4 if supported. | 2013-12-08 10:12:13 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:15 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:15 The network socket is connected. | 2013-12-08 10:12:15 SC Data Service: Connected to server. | 2013-12-08 10:12:15 SC Data Service: Sending logon request message. | 2013-12-08 10:12:15 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:15 Socket closed. No error. | 2013-12-08 10:12:15 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:15 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:15 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:17 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:17 The network socket is connected. | 2013-12-08 10:12:17 SC Data Service: Connected to server. | 2013-12-08 10:12:17 SC Data Service: Sending logon request message. | 2013-12-08 10:12:17 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:17 Socket closed. No error. | 2013-12-08 10:12:17 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:17 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:17 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:19 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:19 The network socket is connected. | 2013-12-08 10:12:19 SC Data Service: Connected to server. | 2013-12-08 10:12:19 SC Data Service: Sending logon request message. | 2013-12-08 10:12:19 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:19 Socket closed. No error. | 2013-12-08 10:12:19 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:19 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:19 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:21 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:21 The network socket is connected. | 2013-12-08 10:12:21 SC Data Service: Connected to server. | 2013-12-08 10:12:21 SC Data Service: Sending logon request message. | 2013-12-08 10:12:21 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:21 Socket closed. No error. | 2013-12-08 10:12:21 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:21 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:21 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:23 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:23 The network socket is connected. | 2013-12-08 10:12:23 SC Data Service: Connected to server. | 2013-12-08 10:12:23 SC Data Service: Sending logon request message. | 2013-12-08 10:12:23 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:23 Socket closed. No error. | 2013-12-08 10:12:23 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:23 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:23 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:25 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:25 The network socket is connected. | 2013-12-08 10:12:25 SC Data Service: Connected to server. | 2013-12-08 10:12:25 SC Data Service: Sending logon request message. | 2013-12-08 10:12:25 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:25 Socket closed. No error. | 2013-12-08 10:12:25 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:25 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:25 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:27 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:27 The network socket is connected. | 2013-12-08 10:12:27 SC Data Service: Connected to server. | 2013-12-08 10:12:27 SC Data Service: Sending logon request message. | 2013-12-08 10:12:27 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:27 Socket closed. No error. | 2013-12-08 10:12:27 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:27 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:27 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:29 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:29 The network socket is connected. | 2013-12-08 10:12:30 SC Data Service: Connected to server. | 2013-12-08 10:12:30 SC Data Service: Sending logon request message. | 2013-12-08 10:12:30 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:30 Socket closed. No error. | 2013-12-08 10:12:30 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:30 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:30 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:32 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:32 The network socket is connected. | 2013-12-08 10:12:32 SC Data Service: Connected to server. | 2013-12-08 10:12:32 SC Data Service: Sending logon request message. | 2013-12-08 10:12:32 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:32 Socket closed. No error. | 2013-12-08 10:12:32 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:32 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:32 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:34 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:34 The network socket is connected. | 2013-12-08 10:12:34 SC Data Service: Connected to server. | 2013-12-08 10:12:34 SC Data Service: Sending logon request message. | 2013-12-08 10:12:34 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:34 Socket closed. No error. | 2013-12-08 10:12:34 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:34 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:34 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:36 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:36 The network socket is connected. | 2013-12-08 10:12:36 SC Data Service: Connected to server. | 2013-12-08 10:12:36 SC Data Service: Sending logon request message. | 2013-12-08 10:12:36 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:36 Socket closed. No error. | 2013-12-08 10:12:36 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:36 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:36 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:38 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:38 The network socket is connected. | 2013-12-08 10:12:38 SC Data Service: Connected to server. | 2013-12-08 10:12:38 SC Data Service: Sending logon request message. | 2013-12-08 10:12:38 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:38 Socket closed. No error. | 2013-12-08 10:12:38 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:38 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:38 SC Data Service: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-12-08 10:12:40 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-12-08 10:12:40 The network socket is connected. | 2013-12-08 10:12:40 SC Data Service: Connected to server. | 2013-12-08 10:12:40 SC Data Service: Sending logon request message. | 2013-12-08 10:12:40 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:40 Socket closed. No error. | 2013-12-08 10:12:40 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:40 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:40 SC Data Service: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-12-08 10:12:42 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-12-08 10:12:42 The network socket is connected. | 2013-12-08 10:12:42 SC Data Service: Connected to server. | 2013-12-08 10:12:42 SC Data Service: Sending logon request message. | 2013-12-08 10:12:42 SC Data Service - Requested data source (eurex) is disabled. | 2013-12-08 10:12:42 Socket closed. No error. | 2013-12-08 10:12:42 SC Data Service: Disconnected from the server. | 2013-12-08 10:12:42 SC Data Service: Data feed disconnected. Will reconnect. | 2013-12-08 10:12:42 . . . . . . |
[2013-12-08 19:21:29] |
This is now resolved. You will now have a successful connection to the SC Real-time Data service. We also corrected the date on the What is New page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
