Date/Time: Fri, 19 Apr 2024 04:27:31 +0000
Issues with stops and break evens
View Count: 753
[2019-08-16 23:52:51] |
User142227 - Posts: 19 |
I am having an issue with my stops and break evens not calculating correctly. I have a 10 tick fixed stop on my trade window which is being calculated as a 9 tick stop, and my break even trades are often netting out in gains. In this attached example, you can see that every loss was calculated as a 9 tick stop (NQ at $5/tick with a 3.9 round trip commission. You can see also see that the 21.10 trade was a trade where I had moved my stop to break even. http://www.sierrachart.com/image.php?Image=1565999434601.png |
Annotation 2019-08-16 125349.png / V - Attached On 2019-08-16 23:46:58 UTC - Size: 97.25 KB - 242 views Attachment Deleted. |
[2019-08-17 06:22:15] |
This involves simulated trading. So therefore refer to this section: Trade Simulation: How Orders are Filled That section should answer all of your questions. We do not analyze specific trading cases as that is not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
