Date/Time: Sun, 02 Feb 2025 03:58:00 +0000
Data Feed
View Count: 813
[2019-08-16 18:32:32]
BigPapi - Posts: 9
I am looking to add data for the ES only. What are my options?
[2019-08-16 18:34:49]
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
[2019-08-16 18:36:23]
BigPapi - Posts: 9
Unfortunately.... TD
[2019-08-16 18:52:11]
BigPapi - Posts: 9
Anyone there?
[2019-08-16 19:09:33]
BigPapi - Posts: 9
Hoping to get this setup before Monday, but its not looking good.
[2019-08-16 19:34:39]
BigPapi - Posts: 9
Been over an hour since I asked my question.
[2019-08-16 19:56:20]
In this case you will need to use the Denali Exchange Data Feed and you can take advantage of the nonprofessional CME fees. Refer to the instructions on this page:
Also, there is all of this weekend to get set up. So there is plenty of time. We are available on the weekend as well.
Date Time Of Last Edit: 2019-08-16 19:57:07
[2019-08-19 14:52:57]
BigPapi - Posts: 9
I believe that I have added the right services, not certain. Again, I am looking to get ES, would like to be able to trade through Sierra to my account with TD. If that doesn't work, I would like to at least have real time ES on my charts.
Seriously need help here. Thanks
[2019-08-19 15:18:58]
SC Support - Posts: 1919
Papi we were here all weekend waiting to help set you up, where were you? I can give you a call now if that would help.
[2019-08-19 15:23:28]
BigPapi - Posts: 9
A phone call would help me greatly. I need help. Thanks.
651-247-7822
[2019-08-19 15:47:09]
Hi there, refer to: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges*
You can begin at step 5.
[2019-08-19 16:39:49]
Hi there, were you able to get through those steps? Is the datafeed flowing for you?
[2019-08-19 16:43:51]
BigPapi - Posts: 9
I am able to see data from new chartbooks, but I am having trouble with a saved chartbook that I have. It wont load!
[2019-08-19 16:56:10]
Follow these instruction here, we think this may solve your issue.
Edit Menu: Edit >> Translate Symbols To Current Service
[2019-08-19 17:43:20]
BigPapi - Posts: 9
http://www.sierrachart.com/image.php?Image=1566236540200.png
I did everything on the link you sent and I still get nothing.
[2019-08-19 17:46:50]
Sierra Chart - Max - Posts: 5780
Provide a copy of the Message Log by following these instructions:
Sierra Chart Support
[2019-08-19 20:16:10]
Make sure you also connect to your TD Ameritrade account once a month as explained here:
Date Time Of Last Edit: 2019-08-19 20:16:17
