Date/Time: Wed, 24 Apr 2024 17:01:01 +0000
stop/stop limit
View Count: 835
[2019-08-16 18:01:49] |
User906638 - Posts: 3 |
Hello, could you please tell me how to have a keyboard shortcut to move (stop/stop limit) orders up and down on the chart, kind like the case with the limit orders? thank you |
[2019-08-16 20:28:56] |
Refer to the trading Keyboard Shortcuts section here: Basic Trading and the Trade Window: Trading Keyboard Shortcuts You can set Keyboard shortcuts for Stop Order Tick Up/Down. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 20:29:04
[2019-08-16 22:45:42] |
thanks for the quick response, sorry for not making myself clear what I meant is a non-attached buy/sell stop or buy/sell stop- limit order, is it there and I did miss it?
[2019-08-17 09:53:09] |
This is not supported to move those by keyboard.
