Date/Time: Sun, 02 Feb 2025 00:40:51 +0000
Data feed
View Count: 799
[2019-08-16 17:10:16] |
mikeindigo - Posts: 3 |
Hi Support, My data feed for Cryptocurrencies is blank when loaded?? This is the only reason I signed up to Sierra and it doesnt work??? Please help |
[2019-08-16 17:26:00] |
We are not understanding this. This does not make sense to us. Do you mean when you go to File >> Find Symbol, the list is blank? We want you to open a chart following the instructions here: https://www.sierrachart.com/index.php?page=doc/GettingStarted.php#AlternateOpeningCharts For the symbol : XBTUSD-BMEX Let us know if you get the chart and it updates in real time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 17:30:23
