Date/Time: Sat, 20 Apr 2024 08:22:06 +0000
Performance
View Count: 503
[2019-08-16 16:39:43] |
rahul - Posts: 160 |
My question is around the performance... I run about 12-14 studies in total i.e 14 charts in total. Each study take about 5-10ms to run... so this is a total of 140ms for all studies to calculate. I have set the variable sc.UpdateAlways = 1 with a chart refresh interval of 100ms. Do you think I will have performance issues? Should i increase the chart refresh interval to > 140ms for each chart? Also I have all these 14 charts in same workbook. Do you think I should spread them out on multiple workbooks? Currently all 14 charts run on single instance. Should I have multiple instances running, so it can utilize the CPU threads better? Thanks again for your help. Date Time Of Last Edit: 2019-08-16 16:42:58
