Date/Time: Fri, 29 Mar 2024 04:51:18 +0000
Error with formula in spreadsheet and memory error
View Count: 615
[2019-08-16 12:51:55] |
User276885 - Posts: 2 |
Hello I try to write a new formula in row 3 like I do in others but the result of the formula I only see it in that cell and no in the complete column. I attach an Image. Thank you I have seen too the error "out of memory". What that means? thank you |
formula error.png / V - Attached On 2019-08-16 12:49:01 UTC - Size: 174.61 KB - 217 views memory error.png / V - Attached On 2019-08-16 12:49:11 UTC - Size: 7.86 KB - 180 views Attachment Deleted. |
[2019-08-16 20:43:21] |
Very unusual to get a pop-up that says "out of memory". That is not a Message Box that our software would directly display. Must be happening at the operating system level. Attach your spreadsheet file here following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Be sure to save it first with File >> Save. And tell us the exact formula you are entering and what cell you are entering it into. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-18 20:44:39] |
The problem is not in the formula. If I open a new spreadsheet study and I introduce new formulas everything ok. When I save it, I close the study, I open a new chart and I open the study, if I want to add a new column wiht a new formula it doesn´t work good. I can create new study but I have problems if I want to modify it. DO you know where is the problem? Thank you. |
[2019-08-19 20:19:35] |
Attach your spreadsheet file here following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Be sure to save it first with File >> Save. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-19 20:19:51
