Date/Time: Thu, 21 Nov 2024 12:40:53 +0000
Adding usage credit
View Count: 787
[2019-08-16 03:28:00]
User628 - Posts: 18
Hello. I've tried to add usage credit but it won't let me. Not sure why? I click on make a payment of 26. Then it gives me two options so i click authorize.net and it goes to the next screen says continue but it doesn't go anywhere. Have tried over and over same thing
[2019-08-16 06:56:04]
Yes we observe this ourselves. We are looking into it now.
For now use PayPal.
[2019-08-16 13:25:11]
User628 - Posts: 18
Paypal won't let me use my card for some reason or I would've done that. So i'm screwed til you fix it
[2019-08-16 20:36:48]
There was nothing for us to fix. But the pop up window from Authorize.net should be working now. Apparently they had a problem earlier.
However, we do consider the integration that authorize.net provides as substandard and we are looking at using a different method.
If you still have trouble making a payment we can give you a usage time extension.
Date Time Of Last Edit: 2019-08-16 20:37:37
[2024-10-24 14:16:51]
User561690 - Posts: 3
Cant add usage credit, have tried several time
[2024-10-24 16:48:49]
John - SC Support - Posts: 36174
Which option are you trying to use on the Payments Page?
[2024-11-10 05:23:06]
nord - Posts: 4
i need to top up $12 USD more for next month's package but it doesn't allow me to top that amount, only fixed at $46, even if I manually change it to $12.
[2024-11-11 01:42:42]
Sierra_Chart Engineering - Posts: 17133
We apologize for the delay with responding. Go to this page here:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit#MoveToTop
Near the top you will see this section:
Payment Form for Account: (your account name)
Specify USD Amount: (Here in this box enter the USD amount and then choose the payment option you want to use below)
Let us know if you need more help. We did a test, and the amount specified, in USD does carry forward to the next payment page for the payment option you chose.
Date Time Of Last Edit: 2024-11-11 01:44:14
