Date/Time: Thu, 28 Mar 2024 10:40:19 +0000
CL (sc feed) missing daily bar for 8/14
View Count: 532
[2019-08-16 00:18:07] |
cmb999 - Posts: 211 |
have refreshed . .
[2019-08-16 01:33:05] |
File attached
cl_dailybar.png / V - Attached On 2019-08-16 01:31:16 UTC - Size: 112.95 KB - 233 views |
[2019-08-16 05:04:45] |
Refer to help topic 6: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-16 14:19:32] |
deleting all and re-downloading didnt fix. restart sierra fix. maybe it was the combination redownloaded before 1st post, but didnt restart till this morning Date Time Of Last Edit: 2019-08-16 14:22:33
