Date/Time: Sun, 24 Nov 2024 21:42:39 +0000
[User Discussion] - moving average, current day only
View Count: 1466
[2013-12-08 14:34:21] |
Todd - Posts: 62 |
I would like to create a moving average of period 100, but I would only like to consider bars from the current session. If I'm on bar 10 of the current session, then I would only like to have those 10 bars in the MA calculation. Is there a way to accomplish this? Thanks for your help.
[2013-12-09 02:55:04] |
vegasfoster - Posts: 444 |
I can do this within next couple days.
[2013-12-09 03:05:28] |
Todd - Posts: 62 |
Vegas- that's very generous of you!
[2013-12-10 19:12:15] |
I have the cutoff set how my brain works, but take a look and if it's shifted of how you think of it then I can change it. Also, if you want to use an exotic moving average not listed, e.g. T3, then I will have to add it manually. Let me know.
GregoryMA.cpp - Attached On 2013-12-10 19:11:37 UTC - Size: 1.97 KB - 540 views GregoryMA.dll - Attached On 2013-12-10 19:11:52 UTC - Size: 17 KB - 465 views |
[2013-12-11 02:12:19] |
Todd - Posts: 62 |
I just gave this a try and it worked perfectly, and had all the parameters I was expecting. Do you work for Sierra Chart.. how can I thank you for your help? |
[2013-12-11 06:29:48] |
[2013-12-11 15:02:17] |
Todd - Posts: 62 |
Whatever the case, thanks Vegas! Looking over the code was helpful as well.
