Date/Time: Fri, 26 Apr 2024 05:04:39 +0000
ACSIL: Access All Ticks Per Bar
View Count: 800
[2019-08-15 18:21:33] |
User41727 - Posts: 124 |
I was wondering if there is a way to access a list of all ticks that belong to a bar in ACSIL. Couldn't find anything in the documentation. Collecting them on each call of the function only works in real time, but not for historical bars, which is not ideal for my use case.
[2019-08-16 07:29:31] |
Refer to: sc.ReadIntradayFileRecordForBarIndexAndSubIndex() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
