Date/Time: Fri, 26 Apr 2024 19:08:38 +0000
Error Not Connecting
View Count: 1069
[2013-12-08 12:56:12] |
User76055 - Posts: 18 |
Getting an error not connecting this morning, upgraded to version 1061. Attached is the error file. Thanks, Pete |
Private File |
[2013-12-08 19:24:28] |
This is the relevant error message: Zen-Fire - Server Alert: Trading System Connection Login Failed. Error text: permission denied | 2013-12-08 06:48:57 Refer to step 14 here about this: https://www.sierrachart.com/index.php?l=doc/ZenFire.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-08 19:25:23
[2013-12-08 19:26:43] |
Its working now, probably like step 14, a Zenfire issue...Thanks!
