Date/Time: Sat, 20 Apr 2024 13:12:57 +0000
about Chart Settings
View Count: 522
[2019-08-15 16:20:13] |
User270832 - Posts: 8 |
Hello Is it possible to do both at the same Time: Using interactive Scale Range and Interactive Scale Move ? |
[2019-08-15 16:20:54] |
Sierra Chart - Max - Posts: 5590 |
Yes, you can do that by temporarily inverting the scale mode by holding down the Ctrl key: Chart Scale and Scale Adjusting: Inverting the Scale Mode Sierra Chart Support |
