Date/Time: Thu, 25 Apr 2024 21:19:22 +0000
average position price incorrect
View Count: 1494
[2019-08-15 16:08:43] |
User185210 - Posts: 57 |
Dear SC support, I have an issue with the average position price that is not correct: Setup is as following: 2 instances: instance 1 has 10 charts with spreadsheet for trading used on 4 charts, the average position price is correct on 2 charts and not correct on the chart I use to trade with using automated exit,scale in,out and attached orders activated. Another thing is that the sub-instance has also the wrong average price displayed. What could I do to fix that error? Thank you in advance your feedback, Kind regards, Paul |
[2019-08-16 01:11:54] |
Refer to the following, and make sure that you are using the same setting to calculate the Position Average Price in all the charts: Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
