Date/Time: Thu, 17 Sep 2026 05:42:27 +0000
after the free trial
View Count: 959
| [2019-08-15 14:24:19] |
| User223358 - Posts: 6 |
Hi, I am on the free trial now. Let's say that I begin only in 1 month in real time, will I lose my set up that I have on the free trial (chart and dom) ? Thanks! |
| [2019-08-15 14:28:15] |
| SC Support - Posts: 2103 |
Are you asking if you can maintain the Chartbooks that you are creating in the Trial/Demo period, when you move to a paid account? Yes is the answer to this question.
| [2019-08-16 00:59:19] |
You will never lose anything you have created in Sierra Chart because it remains as it is on your computer system, under your own control, and is not affected in any way based on the status of your Sierra Chart account or any other account you may use.
