Date/Time: Thu, 25 Apr 2024 00:15:03 +0000
Too many alert sound - all symbols open tab
View Count: 511
[2019-08-15 12:28:09] |
ez2000 - Posts: 7 |
Hi! I been getting volume alert sounds on all chartbook tabs (different symbols). In each chartbook, I only have one time and sales window with an alert but I am getting all alert on all chartbook. Is there a way to stop getting alert sound on other chartbooks that is on my screentab but not opened? It's driving me nuts to hear all different chartbook with different symbols producing volume alert sound. I would like to just limit it to current chartbook that is open.
[2019-08-15 15:06:21] |
Any configured alerts will be generated from all loaded Chartbook's. You can mute all of them through Global Settings >>Mute All Alert Sounds.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-15 15:06:41
