Date/Time: Fri, 26 Apr 2024 16:34:39 +0000
Significant lag in data feed
View Count: 826
[2019-08-15 12:11:46] |
User345195 - Posts: 7 |
Hello, for the third day in a row I have had a lag in the data feed every time the market starts to move quickly, this is on the Micro NQ, I am not sure if this is an issue with sierra chart or CQG however each time this has happened I have lost money due to the lag. I updated the latest version of sierra chart so I am not sure what is going on but now that it has happened on multiple occasions I have decided to post as see if you can help. Please let me know if there is anything I can provide for you to figure out what is going on. I have a trading partner and the same thing has happened to him at the same time so I imagine this is not the first time you are hearing about the issue. Look forward to hearing back from you because as of the moment I do not feel safe to trade. Thank you.
[2019-08-15 12:48:49] |
User657944 - Posts: 173 |
Same issue yestarday with Transact version 1941 or 1973 it does not matter when that kind of big volumes in short timeframes come out the dom is following the price while the charts are in delay from 30 sec to 1 min depending from the intensity of the vol spike.
[2019-08-16 01:08:48] |
In regards to post #1, we can give you free for the remaining month, access to the Denali Exchange Data Feed. You can then compare to CQG and see if it solves your problem. Here is more information about this data feed: Denali Exchange Data Feed Would you like that? Please let us know. Also refer to help topic 4 in regards to issues like these: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 06:38:22
[2019-08-16 13:38:49] |
Thank you for getting back to me so quickly and it is very generous to offer a trial period of the Denali Exchange Data Feed. I would be very interested in trying it out but wanted to check with you to see if this is possible to do with Tradovate being my FCM? If it is possible I would like to try the new exchange, thank you!
[2019-08-16 17:56:28] |
We have added a $15 credit to your account. This is enough to cover the cost of the data feed until the end of the month and there is no cost for the exchange fee for the first month. Follow through the instructions on this page here: Denali Exchange Data Feed This data feed will work with any supported service including CQG which you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 17:57:35
