Date/Time: Fri, 29 Mar 2024 13:19:43 +0000
crosshair
View Count: 1617
[2019-08-15 11:12:55] |
User143551 - Posts: 96 |
using the hand on mouse , my crosshair color needs to be changed to black its red now
[2019-08-15 16:15:18] |
John - SC Support - Posts: 30446 |
The crosshairs color can be changed under Global Settings >> Graphics Settings >> Chart Values: Crosshair. Refer to the documentation for this setting here: Graphics Settings: Chart Values: Crosshair If you are asking about changing the color of the hand cursor itself, then that is done through the operating system. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-15 17:16:59] |
it will not me change the color it stay red
[2019-08-15 21:04:30] |
We will call if necessary but there are two Graphics Settings windows. One global one and one for the active chart. You need to set the Chart Values: Crosshair color on the appropriate one. Refer to: Graphics Settings: Introduction Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 20:07:28
[2019-08-19 20:12:25] |
I have 4 different charts of es all of them are set to 2 minutes and the count down timer is on on all of them two charts run 24 hrs setting ,and two are set to open at 9:30 est close at 4:15 est ,the two set for 24 hrs do not change the time as the 9:30 est charts , the bars on the monitor don't change at the same time ,even though they all are set for 2 minute bars,and the count down timer is off
[2019-08-20 04:29:28] |
Refer to the documentation for the Countdown Timer study: Countdown Timer There is a study Input for a continuous countdown based on the real-time clock. Read about that and make sure that is set as you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-20 04:29:52
