Date/Time: Fri, 29 Mar 2024 04:57:14 +0000
Chart Settings
View Count: 632
[2019-08-15 07:37:47] |
User270832 - Posts: 8 |
Hello Is it possible to do both at the same Time: Using interactive Scale Range and Interactive Scale Move ? Date Time Of Last Edit: 2019-08-15 07:42:43
[2019-08-15 08:32:03] |
Not at the same time but if you hold the Control key on your keyboard and drag the price scale up and down, then the opposite action will be performed.
[2019-08-15 09:15:27] |
Thats good enough for me. i got another Topic. i want to mark out Yesterday Open High Low Close by a Line on the Chart. Ho do i do this the easiest Way ?
[2019-08-15 09:31:53] |
This can be done by using the Daily OHLC study. Refer to: Daily OHLC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-15 21:38:27] |
Ok,and how do i mark Last Week and Last Month OHLC ?
[2019-08-16 05:01:32] |
Use this particular study: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-16 05:54:52] |
Superior Support! Thx
[2019-08-18 10:31:35] |
Another One : Is it possible to draw a Study only on specific Timeframes ? Say. Study 1 only on M1 M5 and M15?
[2019-08-18 11:34:11] |
No, that is definitively never going to come.
