Date/Time: Fri, 26 Apr 2024 15:08:50 +0000
[Locked] - the hand
View Count: 556
[2019-08-14 22:12:32] |
User143551 - Posts: 96 |
how do I change the color on crosshair the hand on the mouse is white I need it a dark color I keep loosing it on white charts |
[2019-08-15 09:23:45] |
You need to go into the operating system Control Panel >> Mouse Properties and then change the "Pointer >>Link Select" cursor.
