Date/Time: Sun, 24 Nov 2024 21:36:32 +0000
Trading DOM Studies
View Count: 2331
[2013-12-08 01:04:23]
User23815 - Posts: 210
In using the Volume by Price study on the Trading DOM, in the subgraph settings, the POC and Value Area lines are set to the default distinctive colors, but I don't see them on the study. Changing the colors seems to have no effect. I am able to show volume numbers by POC only so I assume the study is tracking these points. What do I need to do to see them on the Trading DOM VbP study? Thanks
[2013-12-09 17:00:24]
In the Volume by Price Input Settings, set Highlight Point of Control to Yes. The same for the Value Area.
[2013-12-09 18:42:04]
Thanks, that worked. Also, on the Trading DOM, I am trying to differentiate the day and evening session on the Volume by Profile study. I set the choice in the Input Settings to yes (Use Separate Profile for Evening Session)but it isn't making any difference.I have the chart settings set to day and evening session times. I am on subscription package #3. Thanks
[2013-12-09 18:43:37]
This is not going to work right on a Trading DOM. You will not be able to do that.
[2013-12-09 19:07:26]
Am I able to do it on a chart with the Volume by Price Study? Can it be done in subscription package #5? Thanks
[2013-12-09 19:27:28]
Yes, you can do this on a normal chart only.
[2013-12-09 20:58:15]
I have not been able to do it on a normal chart. I have the Volume by Price study set to From Session Start Time to End. I have the Use Separate Profile For Evening Session set to Yes. I have Day and Evening settings established in Chart Settings. I am still only seeing a single profile for the current day, starting at the evening session and carrying through the day session. While multiple days are visible on the screen, only the current day shows the profile. I also tried changing the study setting to Visible Days and Based on TPO Chart, no difference. Again, I have subscription package #3. Thanks
[2013-12-11 03:36:22]
You need to set the Volume Graph Period Type to Fixed By Time in the Volume by Price Input settings. We will update the documentation to explain this.
Date Time Of Last Edit: 2013-12-11 03:37:28
