Date/Time: Fri, 29 Mar 2024 13:30:52 +0000
[User Discussion] - Horizontal Ray as a drwing style
View Count: 1147
[2013-12-08 00:15:50] |
GPST10 - Posts: 139 |
Hi, Would it be possible for you guys to add HORIZONTAL RAY as a drawing style. That would make OHLC study attached as "study price overlay" usable since it wouldn't draw it backwards, to be used for showing specific time range of OHLC from point of creation forward, used for OPENING RANGE, etc.. Would it work? Currently it works extending lines both ways (on target chart) or copying lines from source chart exactly as is - preventing lines to be used forward in time. Thanks |
[2013-12-08 01:23:46] |
There is no need for us to add another Draw Style, it is just a matter of someone programming what they specifically require. ACSIL is more than capable already to do what you need. We recommend contacting a programmer here for what you want: http://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html#ThirdPartyList Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
