Date/Time: Sat, 20 Apr 2024 02:45:34 +0000
Header menus order changed from older versions
View Count: 570
[2019-08-14 03:39:03] |
Willson - Posts: 176 |
version 1939. I use several detached charts within each chartbook. My chartbook menu ( for open chartbooks)previously was always visible, now (in newer versions)the region containing the still attached charts over laps (obscures) the active chartbook name menu. This is hard to accurately describe, but is simply the order of upper menus has changed. Using Win 7. This change is not helpful, how can I change it? |
[2019-08-14 06:12:46] |
The main menu of Sierra Chart is the same. It has not changed. We are not sure what you mean.
