Date/Time: Thu, 28 Mar 2024 16:15:27 +0000
Dome does not attach to worksheet
View Count: 527
[2019-08-13 22:52:57] |
Gerald L Reynolds - Posts: 7 |
[2019-08-14 04:25:02] |
Not sure we understand the question, but if you want to do this simply go to the Trading DOM and select Window >> Detach/Attach Chart Window.
