Date/Time: Sun, 24 Nov 2024 20:55:03 +0000
Market replay stops
View Count: 1210
[2013-12-07 16:17:07] |
jsmanuse - Posts: 32 |
For some reason, when I am using market replay, it will stop at random points. After it stops, I have attempted different playback speeds etc., but nothing will restart it. I am manually backtesting and so am not employing any additional scripts. Can you advise? |
[2013-12-09 02:42:23] |
While looking into this problem, we discovered an issue when using Skip Empty Periods on the Replay window. It was not working as intended. This is now fixed in the very latest prerelease. Update with Help >> Download Prerelease. We also thoroughly updated the Documentation on this subject. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#SkippingData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
