Date/Time: Sun, 02 Feb 2025 00:33:49 +0000
will not connect
View Count: 588
[2019-08-13 17:04:03] |
User788201 - Posts: 2 |
the data will not connect... i get a continuous loop of "waiting to connect" please fix. a phone number would be helpful if the fix is not simple. thank you |
[2019-08-13 19:56:27] |
We cannot solve CQG connection issues. We see that is what you are using. Refer to the setups instructions here: CQG Trading Platform Service: Setup Instructions And then contact your broker for help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-13 19:56:53
