Date/Time: Sun, 02 Feb 2025 00:48:54 +0000
Quotes and Charts not keeping up with Market!!!!
View Count: 654
[2019-08-13 16:23:39] |
KXRCap - Posts: 64 |
ES is way off what is going on!
[2019-08-13 19:25:02] |
Refer to help topic 4: Prices / Data Falling Behind You are not using a Sierra Chart provided data feed. We can only refer you to the above help topic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
