Date/Time: Sun, 02 Feb 2025 00:33:21 +0000
My data is showing gaps on the charts. Need help with this
View Count: 706
[2019-08-13 14:46:43] |
User186212 - Posts: 2 |
My CL data feed is showing gaps in my charts. Maybe it's delayed data. But my oil data is not accurate. I have attached screen shots to better understand the issue. Data feed is off. |
[2019-08-13 19:37:37] |
That screenshot is not helpful to us at all. If you want to post an image of a chart you must follow the method here: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage You need to post an image of only a single chart without any studies. For missing data issue, follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-13 19:38:23
