Date/Time: Fri, 26 Apr 2024 08:35:34 +0000
TSX 60
View Count: 785
[2019-08-13 14:05:00] |
John Ara - Posts: 125 |
Please let me know if Sierra can provide live quotes for TSX 60 (Montreal Exchange)? Thank you. |
[2019-08-13 15:59:49] |
SC Support - Posts: 1794 |
The TSX Exchange is available on the Sierra Chart Exchange Data Feed (Not Denali) Sierra Chart Exchange Data Feed: Supported Exchanges See here if the instrument related to the TSX 60 is included: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=8#TSX |
[2019-08-13 21:44:30] |
Do you want an index or do you want data for the individual stocks?
[2019-08-14 14:58:04] |
I want an Index (TSX 60)
[2019-08-16 20:22:24] |
The Toronto exchange data feed just contains data for individual securities listed on that exchange. But some of them are index ETFs. You can refer to the symbol listing here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=8#TSX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
