Date/Time: Sun, 02 Feb 2025 00:44:24 +0000
Charts not updating [Sierra Chart Data Feed]
View Count: 683
[2019-08-13 14:29:20] |
SC Support - Posts: 1919 |
Hi there, I see that the last time you signed up for real-time data was the month of June, is that your understanding too? If so are you asking why the delayed data doesn't "stream"?
[2019-08-13 16:47:00] |
Sierra Chart - Max - Posts: 5780 |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support |
[2019-08-13 18:44:21] |
For the record you are not currently using the Sierra Chart futures data feeds.
