Date/Time: Thu, 25 Apr 2024 08:48:30 +0000
Do I have to pay data fees twice. Once for Sierra and once for my trading platform?
View Count: 786
[2019-08-13 09:52:13] |
User941433 - Posts: 7 |
Hi, If i use Sierra for my charting but another software package for trade execution. Do i need to pay the exchange live data fees twice? Also, whilst i'm waiting for my trading account to be setup can I get free historical data? Thanks Tom |
[2019-08-13 11:07:59] |
Not normally. What Data or Trading service will you be using Sierra Chart with? See this section for the list: https://www.sierrachart.com/index.php?page=doc/Contents.php#SupportedDataAndTradingServices Yes historical data is available. Refer to: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-13 11:08:48
[2019-08-13 12:15:02] |
Hi, Thanks for the reply, i will be using TT Web most likely. So how does it work, if i get a TT account with my broker i just open an account with you and then i assume theres some product key or something TT give me so you know to use that data? Is there any other cost involved? Regards Tom |
[2019-08-14 09:05:00] |
Sierra Chart does not support the TT data feed, so you do need to use a separate data feed with Sierra Chart and pay the exchange fees a second time. If you are a professional and will be paying professional fees, then you only have to pay them once but that has to be specially arranged and is time-consuming. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
