Date/Time: Fri, 19 Apr 2024 19:31:21 +0000
Chart is not correctly showing bars (IB TWS Realtimedata)
View Count: 774
[2019-08-13 05:49:09] |
koray123 - Posts: 2 |
Hi I am testing SierrraChart and comparing it with TWS chart. SierraChart donot look the same as TWS chart there seems to be data differences Is there any reason for this? Is my configuration wrong? I am using IB realtime data. SierraChart using IB (TWS) Real time data https://pasteboard.co/Isss8Qu.png TWS Chart with realtime data. https://pasteboard.co/IsssyjM.png |
[2019-08-13 23:58:29] |
When posting an image of a Sierra Chart chart, use this method only: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage And for any differences, refer to help topic 43: Differences With Data and Chart Bars Between Services / Connections / Chart Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-14 11:50:09] |
Hey is someone interested in my problem ? Is this an army disipline? I am trying to use/evaluate your product.
[2019-08-15 07:56:15] |
First, we do not accept images from outside websites. And we cannot compare a Sierra Chart chart to a chart from TWS. So no we are not really interested in doing a comparison to TWS. As a matter of policy we will not do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
