Date/Time: Sat, 20 Apr 2024 13:08:53 +0000
BTC China Saying Not Enabled On Package
View Count: 1140
[2013-12-07 07:29:08] |
Ryan Becker - Posts: 2 |
Hello, I have a Sierra Chart account level 2, and my BTC China data feed says that it is not enabled on my package. However, it was working before, and I was able to use it in my charts. Is there some change I'm not aware of, or is there a server software glitch? |
[2013-12-07 20:30:38] |
We are working on solving this now. It will require a software update. However, the service you should be using is named Bitcoin Data (All Services). This gives you access to all of the supported Bitcoin exchanges. You will find all available symbols through File >> Find Symbol.
