Date/Time: Sat, 01 Feb 2025 22:42:10 +0000
Missing data in charts.
View Count: 630
[2019-08-12 16:42:36]
JEM.TRADES - Posts: 16
Hello support,
I'm having the following issue, I have one of my charts with the following session times:
(All times are Central US Time)
Start time: 8:30
End time: 15:15
Evening start: 17:00
Evening end time: 8:29:59
Use evening session is checked.
I go to a 1 min chart and using the crosshair I see that there's information missing. The last bar for the session closes at 15:15 and the bar right after that jumps to 18:00. This means I'm missing information from 17:00 to 17:59:59.
On a different chart, I have the following session times:
Start time: 00:00.
End time: 23:59:59.
Not using evening session.
Using a 1 min chart it jumps from 16:59 to 18:00.
The symbols I used for testing are: RTY and CL.
Any help will be highly appreciated.
Thanks!
[2019-08-12 16:49:10]
It sounds as though the charts are using US Eastern time instead of central time. To change that, refer to:
Time Zone Setting
Date Time Of Last Edit: 2019-08-12 16:49:33
