Date/Time: Sun, 24 Nov 2024 20:22:38 +0000
Commissions don't appear in Trade Activity Log when checking "Use Commission"
View Count: 1890
[2019-08-12 07:33:51] |
User877753 - Posts: 152 |
Hello, SC : 1973 + Interactive Brokers When checking the "Use Commission" checkbox, commissions don't appear in Trade Activity Log, from today's trades as well as earlier in 2019, for the real account (IB) and the simulated one. Don't appear anymore in PL on charts and trade window. Nothing in statistics either. What's happening ? I set the appropriate round turn commission in the Symbol Settings, did not change anything : tried ES / MES / DAX / CL. Could you help please ? Worked fine for monthes / years till end of July. Thank you in advance Date Time Of Last Edit: 2019-08-12 07:35:30
[2019-08-12 17:21:20] |
Most likely you did not enable the Use Custom Symbol Settings Values on the Global Settings >> Symbol Settings window. Refer to the following for enabling Commissions, particularly the links to the section on Use Custom Symbol Settings Values: Trade Activity Log: Use Commission To enable the commission in charts, you need to enable this setting in Chart Settings: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 17:21:58
[2021-01-15 17:52:20] |
pismo10 - Posts: 159 |
Having same issue. Commission shows up in the Daily P/L on DOM, "D:" but not in the Cummul P/L on Trade Activity Log. For example an ES trade. 1.5pt gain shows at 1.42P on DOM with $4Rt comm but Cummul P/L on Trade Activity Log is still full $75. Thoughts? Thks |
[2021-01-15 18:12:47] |
First thing is to check that the Use Commission option on the Trade Activity Log is checked. Refer to the information here: Trade Activity Log: Use Commission For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-26 17:03:22] |
User566250 - Posts: 37 |
Hello, I have a similar issue where commissions shows zero in the Trade Activity Log. Both options below are checked: Checked: Use Custom Symbol Settings Values on the Global Settings >> Symbol Settings window Checked: Use Commission option on the Trade Activity Log I'd appreciate your input. Thanks |
[2024-04-26 17:23:42] |
Do you have a Commission Value entered in the Symbol Settings?
