Date/Time: Sat, 01 Feb 2025 22:56:36 +0000
numnbers bars disappeared
View Count: 647
[2019-08-12 07:30:47]
User554800 - Posts: 1
Just as I made payment to start my subscription I have lost all information from my numbers bars chart.
Its not clear whether payment has been made or not - initial message was that it had, then it looks as though it has not.
Most importantly how to I retrieve the numbers bars chart?
Reply awaited anxiously
JOhn
[2019-08-12 07:37:14]
You need to change to the Advanced service package 5 for Numbers Bars:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
