Date/Time: Sat, 20 Apr 2024 02:46:13 +0000
Denali data service compared to optional service
View Count: 977
[2019-08-11 20:31:03] |
madness99 - Posts: 35 |
Hi, I heard good things about the Denali data service. Can you tell me if I get the Denali data service, would I still need the optional data service? Will Denali cost more than more current data service. Will Denali still works with Interactive Broker with full book. Thanks |
[2019-08-11 22:47:57] |
Here is the documentation for the Denali Exchange Data Feed: Denali Exchange Data Feed If you use this data feed, you do not need to use the Sierra Chart Exchange Data Feed. If you want to transition over to it next month, just let us know here. We will manage that for you. The cost is less. It does work with Interactive Brokers. And supports the same amount of depth as the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-22 14:46:24] |
Sure. Let me know what I need to do to switch. Thanks J |
[2019-08-22 17:28:07] |
We will take care of this for you. But you will need to complete the agreements. You will get a notice about that next week.
[2019-08-22 17:38:53] |
The agreement have been taken care of. Thanks J |
