Date/Time: Sat, 01 Feb 2025 22:49:59 +0000
Customize the 8 Drawing Object Colors
View Count: 733
[2019-08-10 17:20:50] |
User661100 - Posts: 8 |
Hello, I want to change some of the 8 default colors that are available for vertical and horizontal lines. How/where can that be done? thanks, |
[2019-08-10 19:15:12] |
John - SC Support - Posts: 37656 |
Refer to the following: Chart Drawing Tools: Customizing Colors on the Menu For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
