Date/Time: Sat, 01 Feb 2025 23:07:13 +0000
Missing ES Intraday Data In Sub Instance #3
View Count: 710
[2019-08-09 21:32:17] |
ged - Posts: 233 |
Just downloaded SC V 1971, but this gap in data occurred while running V 1956. Have not had missing data in sub instance #2. Occasionally, not often, I experience a gap in data in sub instance #3. The data in question is ES futures thru SC Data. Have updated the symbol settings and fully re-downloaded chart data by selecting “Edit >>Delete All Data and Download”. Gap persists. |
[2019-08-10 23:39:23] |
You need to correct the missing data first in the main instance and then the sub instances. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Historical Data and Missing Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
