Date/Time: Sat, 01 Feb 2025 21:55:39 +0000
cant get data again
View Count: 569
[2019-08-09 18:27:16] |
You are using the Denali Exchange Data Feed which requires an up-to-date version of Sierra Chart. This is the problem: Software version: 1941 64-bit | 2019-08-09 13:54:36.090 Follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
