Date/Time: Thu, 13 Feb 2025 17:36:40 +0000
Time and sales columns
View Count: 705
[2019-08-09 16:25:16] |
GreegT - Posts: 23 |
Hello, great customization platform! Am I able to rearrange the time and sales columns? If I have to edit the code, could you please point me toward the file this code is located? Also is there a reliable way for me to test the accuracy of my data provider? Thanks |
[2019-08-09 17:45:46] |
The Time and Sales columns cannot be rearranged, but you can remove them and change the width of them. Let us know if you need help with either of those. Also is there a reliable way for me to test the accuracy of my data provider? Yes you can do comparisons to the Sierra Chart Historical Data Service data:Thanks Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-09 17:45:57
[2019-08-11 15:12:57] |
Thanks for the reply! Do you know of a good way to test accuracy in a live environment? Also would you consider allowing the rearranging of time and sales columns? I've tested 2 dozen platforms and this is by far the most customizable. It's also the only one where I couldn't rearrange time and sales. The fact it's such a common feature would suggest I'm probably not alone in needing it. |
[2019-08-11 22:37:40] |
We see you are using TD Ameritrade, regarding the accuracy of TD Ameritrade data, in our experience the stock data from that service is fine. We would not really be concerned about it. We will see about customizing the Time and Sales columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-11 22:37:55
[2019-08-11 23:18:47] |
Much appreciated
[2020-12-18 10:31:23] |
Bruce - Posts: 47 |
Good Morning support.....It's time to be able to rearrange the columns on Time & Sales.....I agree with Post 1....Please take another look at this! Thanks Date Time Of Last Edit: 2020-12-18 10:32:57
