Date/Time: Thu, 28 Mar 2024 14:42:05 +0000
Problems with the trading DOM
View Count: 1209
[2013-12-06 19:07:54] |
User96945 - Posts: 1 |
Hello, I've downloaded the latest version of sierra chart as suggested by the pop up window but now the Trading DOM doesn't shows my position, neither my P/L or my DailyPL when an order fills. Need help Thanks |
[2013-12-06 19:25:23] |
We know about this issue. We were solving a problem related to mapping CBOT symbols to the CME exchange code. And there was a bug with that. Version 1060 is now available. Update Sierra Chart by selecting Help >> Download Current Version. Make sure that your CBOT symbols use the CME exchange suffix. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
